Hi,
I have a big problem. If I start TMPEGEnc and want to cut a MPEG-Movie,
the programm log off, after i put in the Settings and klick onto OK, by himself.
What can be the Problem? The CPU (AMD Thunderbird 1,33 Ghz)?
Or ohter things...?!
Thanks 4 help
Chris
i dont very understand what do you mean exactly, because if you use the mpeg tools on tmpgenc they have no "OK" button they have a "RUN" button,than verify if you give a name and the location for the saving.
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 15:09 -
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 10:14 -
Remove subtitles from MKV when converting with TMPEGEnc
By ikarishinji41 in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 10:21 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 20:33 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 00:38
