Hello!
How can I delay DTS audio files?
I use HeadAC3he to delay AC3 but how do I delay DTS...?
Is it possible to decide in DVDMaestro where the audio should start (DTS)
AnonymousGuest
yes in Maestro you can start the audio delayed including DTS - jsut slide the audio track forward ..
AnonymousGuest
How do I know if the audio comes exacly correct?
Delay on DTS file is -88ms
By the way, my DVD maestro says that it can not fin codec for Realtime dislay... ??
What codec am i missing? -
you need to install cinemaster 2000 or prev version cinemaster - its on the spruce installation cd ...
set delay of audio to 24-26 frames to equal -80 to -88ms delay..
you can also use sync audio track .. -
yes in maestro - right click on audio track and assign audio to video track
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 09:34 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 08:06
