im asking cause i have a few cdrw's, but for some reason i cant burn anything on them, is there something i need to do, or is there a certain program?
Have you tried formatting them with NERO using full erase?
It takes about 19-20 min, but it works for my cd-rw's -
what brand CDRW?Originally Posted by jedi
I have that problem with my Memorex discs--can't get it resolved, even using full erase. I've even tried Clone CD--still won't workwhat are you askin' me for...
I'm an idiot! -
It's probably your disks or your burner. I burn CD-RW's with NERO all the time - and I've never had to format a disk, either. I always use the Quick Erase option when it comes time to erase the things.
I've never had any problem with Nero using any type of disc...CDR or CDRW...cheap or otherwise.
And with the RW's I just unwrap em and stick em in the burner....Never formated one yet...when reburning one I do the quick erase.
Questions for you....U cant burn to CDRW, right ...does CDR work fine?...does Nero recognize your drive corectly?...IE does the name of the recording device match your type and model drive? -
No problems using CDrws on my burner with nero. I use Phillips & Verbatim both are 4 X disc types. And thats after numerous quick erases.
Malcolm -
Nero burns RW well. But don't You have high-speed/low-speed drive/media conflict?
I use Pengo CDRW's and never had a problem. What speed are you burning them at?
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
How to burn AVI files onto CDR?
By doofdoofdude in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2008, 11:08 -
Cannot read Nero-burned CDR (Vista) on XP
By walter4h in forum ComputerReplies: 4Last Post: 27th Mar 2008, 02:20 -
burn vob into cdr
By pcb in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2008, 13:28 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 20:48
