    Oct 2000
    The main problem I had with this disc is there are many, many title sets and many menus.
    I sucessfully split the disc to two folders and got the menus to work. Of course, when I click on a button that points to a clip thats in the other folder, nothing happens.
    Other than that, both folders work fine.
    My problem is trying to burn the folders.
    Nero won't do it, stating that there are files that don't conform to the 2k file size (or something like that).
    Prassi is not so finiky, but the program closes right when it's ready to start burning.
    I've tried another burning program (can't remember the name, and I'm at work right now), but I have to choose between ISO, UDF and I think UDF 1.5.
    Neither of the other programs asks me that question, and I didn't know which one to choose.
    Any suggestions?
    I don't have a bad attitude...
    Life has a bad attitude!
  2. have u tried to do a disc image with ifoedit
    Oct 2000
    No. I've never used that feature of IFOEdit, but I'll try it tonight.
    Oct 2000
    Nope.
    IFOEdit won't create an Image.
    It keeps complaining about a missing file.
    Oct 2000
    The problem with this disc is that there are over 90 titles on it.
    Trying to split it seems to work fine - as long as I play the new folders on my computer.
    But in getting it to work I've had to replace several VOB's with "dummy" VOB's (a 0kb VOB lifted from another disc, and cloned over and over, with each copy renamed to replace some of the ones I had to remove to make the 4.3 Gig limit).
    Nero complains about some files not having the 2kb limit (or something like that), and Prassi closes after hitting the "Go!" button.
    So, has anyone backed this disc up onto two DVD-Rs???
    Jul 2002
    Salem, OR
    If Nero keeps complaining, but YOU know it should work, then burn it as a UDF/ISO format disc - just create the VIDEO_TS folder and drop all the files into. Remember, only do this if you can play the menus and VOBs from your hard drive correctly.
    Oct 2000
    Hey, that worked!!
    Thanks.
