a lot of time when im export the time line(movie) the movie was flicking?
like the video play normaly then came back 4or5 frame then restart normaly then few minute later the same, came back 4or5 frame then continue normaly....?
anyone got this prob? help was very apreciated.
dreambill
Results 1 to 9 of 9
are the clips you are using the same time code ? drop frame settings ? are you using 30fps or other fps clips and saving out to 29.97 ? -- are you re-computing the frame rate on your output ?
that was a big 2.2 Go movie in mpeg2 format 352x240@29,97 fps ntsc, i just editing this video, made some cut and past but the same video no other vid with other frame rate, then when i export it, i export it at 352x240@29,97 fps ntcs and encode it with divx pro 5.0.2
the movie was not flicking all the time only flicking for aprox 10sec at a lot of place in the movie, after exporting this video 3 time,i have see the movie not flicking at the same place,and the export setting for the 3 time are identical.
i very not understand what happen.
dreambill
p.s. some time when export, premiere freez then restart few minute later, but when i check the movie where premiere as freez the movie was not flicking at this place, the freezing was not the cause of the flicking. -
yes what ever the output format it freez during the export, but restart to encode few minute later, and the freezing was not the source of the flicking.....
do you think my computer as not anought power to run premiere without probleme?
i have a P4 1600Mhz with 256Mo of dimm(800Mhz)
my board was asus P4TE and Geforce 2 MX400 -
do you think my "main" movie was too big?(2.2Go) and this made some memory probleme? i think i will split the final(timeline) in 4 part before encoding,i give you some news of that tonight or in the next day.
thank.
dreambill. -
no that was not the prob, i have splited the time to 4 segment but after encoding the first one and view it, the movie was always flicking.
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Probleme mit DVD Slideshow GUI 0.9.2.1
By Lehmeier in forum Authoring (DVD)Replies: 14Last Post: 26th Aug 2009, 15:25 -
How to do this in Premiere
By MI6 in forum EditingReplies: 1Last Post: 21st Dec 2008, 15:15 -
Subtitle (Flicking/shaky/not still) on TV only but still on monitor.
By Anime in forum SubtitleReplies: 4Last Post: 17th Dec 2007, 06:30 -
How can I do this in Premiere?
By alegator in forum EditingReplies: 11Last Post: 6th May 2007, 21:30
