hey guys what is the most easiest way to take a divx movie and convert it to vcd???
Hi:
For me it should be TMPGEnc. If you have the right codecs, just select your file as audio and video. Then load the right template. Some adjust must be done for source aspect ratio and video arrange method. Then just wait the encode and FINITO.
THX
8)
Rey -
Hi:
Try this link
http://www.vcdhelp.com/divxtovcd.htm#audio
Hope this can help you
THX
8)
Rey
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 04:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 01:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01
