Hi:
Why do you need an external audio encoder like TooLAME: Audio Encoder to mp2. if you can do it in TMPGEnc.
Why does TMPGEnc have an External Audio Tools for mp2 in the enviromental options, if you can do it directly.
It is a bit confusing. Can somebody explain it to me.
Rey
Results 1 to 10 of 10
because tmpgenc's audio compression functions and bit rate change are not very good and the authors of tmpgenc know that fact - and allow external audio plugins ... why re-invent the wheel since the apps you can "plugin" work extremly well ..
TMPGenc's audio encoding quality is average at best. It will work it just won't sound as good as what toolame can do. Obviously TMPGenc's author realizes that audio decoding isn't his programs strong point which is why he wisely added support for external audio encoders. If you are happy with TMPGenc's quality then you can just use it directly.
Now TMPGenc's frequency rate converter is really bad. If you use it to convert 48kHz to 44100kHz it often adds extremely noticable artifacts and gives the audio a metallic sound. You should definitely use ssrc.exe as an external frequency rate converter in TMPGenc, but again this is optional. -
Hi:
What's ssrc.exe? Where can I find it?You should definitely use ssrc.exe as an external frequency rate converter in TMPGenc, but again this is optional.
Thanks for your time
THX
8)
Rey -
I use TMPGenc all the time to convert from 44.1 captures to 48k audio for my CVD's and I have NEVER heard any audio problems. Now maybe the built-in encoder isn't as clean as LAME but it doesn't give poor sound quality with a lot of artifacts. Having worked with audio for nearly 30 years I think I can tell when something sounds shite (like DAB radio in the UK!)Originally Posted by adam
I have noticed some problems (metallic sound, high-pitched background whine), but only on a few encodes. I don't know why, the pieces of audio don't seem to have anything obvious in common, but I'm no audio expert. Since I started using ssrc I haven't seen that, but I haven't tried reencoding any of the clips that had problems so I can't say for sure.Originally Posted by energy80s
Maybe you have just been lucky, I do not know what it is that causes this severe distortion in TMPGenc's frequency rate converter but I can assure you that it does happen and when it does you will surely know it. It sounds like you are watching a movie inside of a lead pipe. This is a well known problem. I have experienced it myself and if you search the forums you will see that probably close to 100 people have reported this very problem. Use what works for you but I strongly recommend that anyone who uses TMPGenc use ssrc as an external frequency rate converter. At the very least it will probably shorten your encoding time.Originally Posted by energy80s
As for the audio encoding, I said myself that TMPGenc's audio encoder isnt horrible, but that toolame is much better. If you can't hear a difference then use whichever you want, but I can definitely hear a noticable difference in quality, so I choose toolame. You are mixing and matching my statements. The distortion I was talking about is from the frequency changer not the audio encoder. Whether you use toolame or not has no effect on this distortion. -
Adam, I was answering both of your statements.
1. That the built-in MPEG1 Layer 2 audio codec in TMPGenc is OK for most things, unless you are looking for perfection in audio, in which case use LAME.
2. That TMPGenc has never given me ANY distortion/artifacting/metallic sound over the course of the last 6 months when converting from 44.1 to 48k sound.
3. What's your opinion of the built-in codec in DVD2AVI for downsampling from 48 to 44.1?? I would use this for any VCD's I make from DVD sources (admittedly not many as I normally use 48k for audio on CVD's which is my main format). -
As far as my ears can tell dvd2avi's frequency converter is fine but it is very slow. In my opinion ssrc.exe is the best compromise between speed and quality. Like I said, by using ssrc at the very least you will probably decrease your encoding time.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
where is ffdshow MP2 encoder at nowadays?
By wolfdogg in forum Capturing and VCRReplies: 12Last Post: 21st Jun 2012, 20:17 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Use Badaboom as an external encoder in Virtualdub
By kaskaļ in forum Video ConversionReplies: 5Last Post: 21st Oct 2011, 13:38 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 19:45
