I d/loaded a movie in AVI format and it plays ok with sound.However when i converted it using TPMG to Mpeg i only get a few seconds of sound and then it goes silent for the rest of the movie.Has anyone came across this and what the problem might be ? Thanks.
I know exactly what you mean. I have the same problem and when I try to rip the audio using virtual dub just like it says in the How TO section I cannot it does not let me do it? weird plus it saves the avi to a very big mpeg also so if anyone else knows the answers please help!
EvErY0nEs A HaTeR BuT mEE! -
I tried it again and it worked ok this time.I never changed anything so i dont know what caused it
After you have the DivX movie in .avi format, use VirtualDub to rip the audio into a .wav file. Once you have that use TMPGEnc. Open it up and use the wizard if you want. Use the .avi as the video source and the .wav as the audio source. Then you should get a fully functional .mpg file
I tried encoding the same movie 5 times. I tried everything, including using virtualdub to seperate the sound. I think the reason for my success on the sixth time was because I installed some more codecs, nimo.
Worked fantastic. I was surprised how fast virtualdub could pull the sound from a two hour movie, less then 2 minutes.
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 21:48 -
Sound lost after conversion mpeg to avi
By maclinux in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 14:47 -
avi to mpeg -> no more sound
By myk in forum Video ConversionReplies: 22Last Post: 14th Mar 2008, 13:15 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 01:49 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 04:16
