is the best to make a svcd with excellent quality and is playable on most dvd players?
and where do i get them?
tested a few from vcdhelp, but i am not that much satisfied
thanks in advance
Tmpgenc has its own default svcd settings which will work just fine - change motion to high or highest quality though. Unless your looking to make an XSVCD the templates in tmpgenc should do you just fine. You can also change it to 2pass vbr rather than cbr for better quality (takes longer too)
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 14:25 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Substituting Variables in a Wiki Template
By thecoalman in forum ComputerReplies: 1Last Post: 14th Jul 2007, 05:00 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
YUP TMPGENC 2.58
