Does anyone know when ffMpeg the program behind majors wrapper will be updated ? And, is it that program that causes the audio sync problems ?
-S
ffmpeg gets updated weekly to daily. The project page is here
http://sourceforge.net/projects/ffmpeg/ -
Major, So then when you release your new wrapper do you download the latest ffMpeg version to date ?
-S -
Major,
I am curious about 2 things.
1) Will the new version address the out of sync issue for the audio ?
2) Have you ever used ffMpeg to successfully convert a DVD into a VCD with no sync issues ?
-S -
1) Hopefully each version will get better. The sync issue has multiple reasons. Some aren't easy to get fixed and even PC encoders have the same issues.
2) Yes -
Major,
What are the multiple reasons ?
And
Which DVD did you successfully convert ?
-S -
Well, the sync issues I am having (DivX to VCD) appear related to the fact that ffmpeg cannot transcode into different framerates by adding or dropping frames. TMPGenc can do this, but ffmpeg can't. So your video will be running fast (if you go from NTSC Film to NTSC Video like I have to) while the audio is still the right speed (it isn't dependant on framerate, but rather samplerate, which you can muck up as well)
Slaughtering the competition with amatuer-quality VCD authoring abilities... fear my non-l33t skillz.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 01:33 -
ffmpeg can transcode both audios on "dual avi"?
By CactusMan in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2012, 08:25 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 08:17 -
[FFMPEG] Known problem with "Frame size must be a multiple of 2"
By yamyam in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2009, 13:52 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 08:20
