All encoders do that regardless of what mode they are encoding in. That is what motion searching is. Anytime you encode in mpg you have I, B, and P frames that make up each gop. Your bitrate settings determine how many bits get distributed to each gop and from there the encoder distributes those bits to each frame depending on its priority. I frames have a set bitrate. With P frames the encoder looks forward to future frames to determine how many bits that P frame needs. With B frames the encoder looks both to future as well as past frames.Originally Posted by BJ_M
An encoder never just looks at a frame and says, ahh it needs this many bits. It always has to look either forward, backwards, or both to make its decisions.
It seems MainConcept is only doing one pass which explains its speed. If you were to encode in 1 pass in CCE my guess is that it would be faster. Whether or not it would be as high a quality is another question.
Results 91 to 103 of 103
that is 1 gop motion sensing which yes i know all encoders do or attempt .. i meant it goes forward at times a lot -- 10 gops or more ..
my hardware optibase encoder does 2 pass vbr in real time by using its buffer .. but of course it cant buffer more than a few sec at a time ..
the main concept encoder acts like the hardware 2 pass enocder - which i know is doing 2 pass for sure .. -
BJ_M,
maybe that's how they do it. The quality, speed and ability to set max/avg/min would certainly suggest it uses some other method compared to cce/tmpg etc. It certainly sounds like it's possible to do in software too using clever programming...
What I don't like in normal CQ modes like Tmpgenc or CCE uses is that you can't set avg bitrate, I like that in the Mainconcept encoder. On another note, CCE 2.66 is also very very fast in CQ mode... probably even faster. Not sure how the quality compares though... -
Updated review for the new 1.2 version of Mainconcept encoder which should be released shortly, hopefully this week. Most problems seem to be fixed and there are even a few new features added/improved...
http://www.softdeko.8m.com/mainconcept_mpeg_encoder.htm -
Originally Posted by ajp
Well, I think this is sort of a preview of the new version. They wrote on the support forum that it will be out at the end of the week, so I'm hoping tomorrow ...
There remains the problem of pulsating artifacts in the high contrast areas problem that appears in MSPV6.5a and VS6 V6.02 and if the problem is also in the MainConcept encoder. Maybe the problem is limited to the SDK. There are also several other known bugs that were not mentioned. IMHO It is a very impressive encoder and the bugs will be corrected... That's why I sprung for $149.
ajp Have you tried to batch encode several avi's into 1 meg file? -
I haven't noticed any pulsating artifacts, not yet anyway. The only real serious bug I've come across is the large file bug. Let's see the official bugfix list first. I'm just glad they got the new version out so fast! I'm sure new versions will continue to come out now that they've fixed the worst bugs, glad I bought it...
I've tried batch encoding several DV files into one mpeg but only once and it worked fine? -
I think the ones I tried was DV type-2, I also use Win2k though and not XP...
The files weren't very bigh though. Maybe it has something to do with the directshow priority problem in 1.1? You'll have to try again with 1.2... -
I don"t know what the exact criteria you used for your test or the exact specifics of your system but the results that you got Totally conflict with the results that i and probably al lot of poeple get..On my system the speed of CCE is about 25%- 300% faster than Main Concept standalone..Averageing about 3-5 times real time or up to 150FPS, when encodeing Uncompressed YUV2 avi files..and I allways have a lot of Macro blocks on low bitrates in High motion scenes with Main Concept,low bitrates meaning under 2000KBS with Full Resolution AVI, were I can get away with useing CCE at 2000KBS at 704+480 with minimal artifacts..I guess every system acts differently with different sources so these "Test" don"t really show the overall quality and Compatibility of a Product...
Originally Posted by sherlock
No Problem....How do I post it??Well i guess that is the problem..Should I post it as a Single frame mpeg2 file or a Jpeg of the Mpeg2 file, and were to post and I would be more than happy to...
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
