I am using Pinoeer DV333 with a projection TV
with Component Video input.
I can see the interlace artifact on many DVD movie.
If I change to a progressive scan DVD player,
does the problem go away ?
Do I need to buy a HD TV to work with progressive scan player ?
Projection does not necessarly mean progressive.
HDTV sets do appear to all accept progressive input.
To see progressive you need
1) A HDTV or progressive ready set that can upconvert 480i to 480p
2) A HDTV or progressive ready set and a progressive DVD player.
Yes, they quality is stunning. -
I don't remember that there is setting for 480i vs 480p
in TV setup menu.
Do the TV auto detect the two modes ?
The TV resolution is the same in both 480i and 480p,
the picture quality should be the same, except when there
is fast moving scence.
DVD is actuall 740 lines, is any DVD and TV combination support
740 lines ? ( I saw some TV boost 800 lines resolution )
Please comment. -
You need to do more research, but to clarify.
DVD resolution != TV resolution. Something I learned quite a while ago ( through a massive flame war ) "lines of resolution" does not mean anything like what a computer person might think. A quick google of "lines of resolution" will help you figure out what it really means.
480i = Standard NTSC interlaced video
480p = Double NTSC scanrate and progressive.
Most HDTV's are progressive NATIVLY, and upconvert 480i to 480p or greater.
To learn more
http://www.avsforum.com/
http://www.hometheaterspot.com/ -
dvd isnt 704 lines -- its 704 pixels - 525 more or less linesOriginally Posted by SingSing
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 23:46 -
Trying to find Capture Card - w/ Component input
By tS_veXed in forum Capturing and VCRReplies: 63Last Post: 21st Nov 2008, 08:08 -
leadtek PxDVR3200 H - HD component input
By Thalandor in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2008, 21:10 -
Has anyone seen the SD component input to h.264 Blackmagic Video Recorder?
By edDV in forum Capturing and VCRReplies: 0Last Post: 18th Jul 2008, 21:27 -
Capture card with Component (RGB) Input and 16:9 Support
By edt in forum Capturing and VCRReplies: 21Last Post: 27th Jun 2007, 10:58
