I just purchased a Pioneer DVR-104 and the first couple of movies I did where fine. Because they were under the 4.35gb limit. But now i'm trying to do Mission Impossible a movie that is over the limit.
I used SmartRipper to Rip the dvd. And with this disc it has a widescreen version and a standard version.
there are 8 vobs in this disc. 1 - 4 are the regular version and the very end of vob 4 is the start of the widescreen version
I have tried just burning the .IFO files and vobs 1-4 for the standard version and it gets to about 98% of the burn using Nero and it fails.
right now i'm did the DVD2AVI process and am using ReMpeg method as stated in a previous how-to forum. will this work?
Any suggestions?
do u use ifo edit at all?
sure u can use rempeg to trancode the movie to a smaller size and then remux it back with the audio with ifoedit.
dont forget to do a get vts sectors on the ifo files before u burn
are u keeping the original menu or just the movie and no menu?
how big is the widescreen version that u r burning?
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD Burning problem
By eXit- in forum Authoring (DVD)Replies: 7Last Post: 1st Aug 2007, 10:42 -
Problem Burning to DVD
By schi0249 in forum Authoring (DVD)Replies: 6Last Post: 28th Jun 2007, 16:03 -
DVD burning problem
By ea7770 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2007, 15:17 -
DVD burning problem
By thakurlokesh in forum DVD & Blu-ray WritersReplies: 13Last Post: 27th May 2007, 14:32
