I WANT ONLY MOVIE AND I ALSO RIP OUT OTHER LANGUAGES AND SUBTITLES WITH IFOEDIT, BUT I STILL HAVE SIZE 4.868.000?
IS THERE ANY SOLUTION TO CUT END CREDITS PERHAPS?
Use Ifoedit. Load up the IFO file of the movie. Select Vob extras. On the information box that follows, select split in to two dvd-r's. The next window that pops up will give you a break down of all the chapters in the ifo file and it will also give it's two cents on where the split should occur (usually a the layer split point). Change the split point so that the entire movie goes on one disc, and the end credits goes on the second disc (this is usually the last chapter). After IFOedit is done processing. Just delete the files from the second disc that were created. You now have the first disc files (ifo, bup, and vobs containing the entire movie sans end credits). Load the ifo files in IFOedit. Select "get vts sectors". Burn it!!!
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 07:58 -
How to use Wi-Fi feature in a Blu-ray DVD player to play a DVD movie or vid
By coody in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Sep 2010, 05:01 -
converted AVI to DVD, VIDEO_TS is created, but once on DVD, movie is green
By jens.3 in forum ffmpegX general discussionReplies: 3Last Post: 18th Dec 2009, 01:43 -
i have a 4 year old dvd burner that seams to burn a full dvd but the movie
By dr.bling in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Aug 2009, 23:20 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55
