using dvdx2.0 I have ripped to 3 mpeg2 files .when burnt to svcd with nero i think the quality has been lost to much.I had suggested to me i use easy cd and used the existing mpeg2 already ripped .no improvement.
can I improve on the mpeg2 files I already have or shoould I reencode in a different manner. I want the simplest and easiest quickest with quality.![]()
What is the source ? - DVD Rip. If it is then just use TMPGEnc (easy) or CCE (tougher) to encode - then use Nero but don't let it reencode (if you create a non-standard VCD or SVCD). If you have crap mpeg files then reencode them from the origial VOB's (DVD Rip) - you cannot improve the quality of them by reencoding again (infact you;ll make themmuch worse - just delete them and start again).
Did Nero re-encode the files? DVDx should create compliant files, so it shouldn't have to encode them again. You may want to double check all the settings in DVDx also.
Hardsub HD AVIs without quality loss?
By zf1223 in forum SubtitleReplies: 3Last Post: 2nd Apr 2010, 17:34 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 15:56 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 12:01 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 02:03 -
Quality-loss due to transcoder?
By joelson in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 16:28
