To once and for all make these standalone DVD's region and MacroVision free, follow these steps:
Now, burn the modified firmware files to a CD-R or RW
- Download the latest firmware from VESEG.
Download the ABconf utility
Unzip the 4 firmware update files
Start ABconf and locate the firmware update files it asks for
Change the region setting to 0 by right clicking to bring up the dialog
Set Audio DACs to 3 to enable 5.1 sound
Set Macrovision to "disable"
Search thru all available options in the tree, looking for language/country specific settings, and enable/select the options that apply to you
Save
Insert this CD in the DVD and pray that the power wont go during the update process, which will start automatically, as soon the DVD recogizes this as an update disc!
Done.
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Will this "trick" solve the NTSC vs.PAL problem as well?
I have a Hitachi P-415U and it works only on NTSC. -
Not the faintest idea, since I've never tried anything NTSC. Anyone else?
/Mats -
Hello, I've seen your post and I'd like to ask you if you know if it is possible to modify the firmware 4.1 of my 'SEG 2216 Las vegas' to make it cappable to show the subtitles of my SVCDs. I've seen with the ABconf a lot of options and I've modified the ones that make my DVD macrovision off and region free but I'd like to see my SVCDs with subtitles.
Thanks in advance -
Nope - no idea. I'd guess that's more than a parameter setting - like a firmware patch. I could be wrong tho - didn't even know that SVCD subs wasn't supported, as I always encode my SVCD with permanent subs. Try contacting VESEG to see what they have to say for themselves.
/Mats
Installation of a large CM Gemini II CPU HS in a HTPC
By redwudz in forum ComputerReplies: 5Last Post: 3rd Oct 2008, 19:18 -
disc incompatibility seg 3000
By bryanmansfield in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Mar 2008, 14:32 -
Libra 0.8.0: Beautiful DVD cataloging software (free)
By PictureToTV in forum Latest Video NewsReplies: 2Last Post: 13th Aug 2007, 18:37 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
