I have the Matshita DVD-RAM LF-D310 dvd burner and I also use Nero for my burning software. The problem comes with these 2 comunicating to each other. I have burned with Nero using my Matshita drive for maybe 6 or 7 times successfully (DVD's didn't work right on my standalone dvd player, but they were burned on to the dvd-r). Now when I try to write the DVD, Nero says its waiting for the drive information and waiting and waiting...it never finds the info. My computer shows that the Matshita is working correctly and I also can play DVDs on it. But still Nero and another software that I have use are having trouble reading it. Does someone out there know anything about Matshita, because there is nothing out there that has helped me yet. Any help would be great.![]()
one more thing....I have the updated version of Nero that does work with the Matshita, v. 5.5.9.0 . So thats not the problem
Works fine here, both in and out of a Firewire enclosure.
Sorry can't help you. Is your Windows install or your Nero install correct?
Question on DDR2 RAM
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2011, 07:01 -
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 11:50 -
Problems burning DVD+R DL with Matshita UJ-850S
By Pablo2k1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Jan 2009, 10:06 -
RAM question
By mvp in forum ComputerReplies: 3Last Post: 7th Jun 2008, 15:03 -
matshita dvd ram uj 840s
By skaterboii in forum DVD RippingReplies: 3Last Post: 16th Jul 2007, 04:11
