  1. im trying to convert a mpeg(vcd) to a mpeg2(svcd) using tmpgenc plus but i keep getting a privilege order error(i think thats what it says) in diffrent parts of the movie.i was woundering how i can stop this??anyone know how to stop this error??????
  2. I am having similar problems. What operating system are you using? I am using Windows XP Pro to try to convert an 11Gb file of digital video to a DVD compliant MPEG2. TMPGenc gives me the same error message you had after about 5 minutes into the source. ULead DVD MovieFactory and Workshop crash while encoding as well. I am starting to Think there are issues with Windows XP Pro. I will try to see if it is a file length issue.
  3. im running xp....
  4. Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or 3.
    Then try installing PowerDVD or WinDVD DVD playing software
    to refresh your directshow mpeg-2 codec.
