i have a video clip that plays fine in windows media player, but when i try to encode it using tmpgenc, all i get is static. any ideas?
Playback may be using another codec, but when it comes to editing or converting, the correct codec may be missing.
Load into Vdub and select file > file properties
this will tell you what the codes are, make sure you have them installed.
Also try this in TMPGEnc
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
Subtitle Workshop Acting Weird
By Startropic1 in forum SubtitleReplies: 4Last Post: 14th Jul 2010, 22:51 -
TMPGEnc Authoring Works v4 – weird warning.
By redpol in forum Authoring (DVD)Replies: 2Last Post: 18th May 2010, 09:05 -
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 10:17 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 13:50 -
xvid files act weird in TMPGENC
By briansmccabe in forum Video ConversionReplies: 4Last Post: 11th May 2007, 23:53
