  1. Can anyone please explain how to convert popular file types (.mpg, mpeg2, DivX, etc) to .wmv format or point me to a guide? i didn't see any guide to the .wmv format on you site, but maybe i'm blind today or something thank you for your help. oh yeah, i do have TMPGEnc Plus 2.5, i'm not sure if that will do it or not, but any help is appreciated.
  2. Guest
    Try Microsofts site. I have used the Windows Media Encoder to
    encode files in the past to .wmv format. I even hear there is
    a new version out.
    BTW: Why do you want to convert mpg to wmv? MPG is much easier
    to work with.
  3. Thanks a lot Megadeus, that's the kind of info i was looking for, someplace to read up on it I heard wmv gets good compression, usually around 150 meg/cd, if the person who was telling me was correct, and i wanted to archive somethings on cd's without it taking forever with my slow 4x burner. I use a tv-out to watch movies anyway, so it doesn't make much difference if it's in a vcd or wmv format. thanks again.
  4. Banned
    Jun 2001
    UK
    Why do you want WMV, and converting a DivX to WMV is not going to achieve much, as the DivX is using a good compression anyway, and if you used a higher bitrate you could end up with something much larger.
    Vdub
    Video > full processing mode
    Video > compression > codec > DivX 3.11 Alpha (Low motion) > bitrate (start with 400)
    Audio > full processing mode
    Audio > compression > codec > DivX or MP3 > bitrate > (chose one that uses the same frequency and a low bitrate)
    SAVE AVI
    But remember if your source is poor your output will also be poor
    Vdub will handle AVI, Mpeg 1 but not Mpeg 2, you need to use TMPGEnc for Mpeg 2 with file > output to file > AVI etc
    Or use M$ MPEG 4, V3 which will be the same as WMV
  5. archiving in wmv? usually you want to store your videos in the highest quality available... just in case in the future you want to edit them and/or recompress them. if u store your video in that format...you're really limiting your options. Divx is the way to go! yeah if your streaming video...wmv [and .rm] are goood codecs.
  6. "Why do you want WMV, and converting a DivX to WMV is not going to achieve much, as the DivX is using a good compression anyway, and if you used a higher bitrate you could end up with something much larger."
    I didn't know that, thanks for the info, you're right, i read up on it some more, DivX does seem to have a lot more advantages. I'll take that route.
    Thanks guys.
