  1. I have a Toshiba SD-2800 player which ive checked on the list and is compatiable for VCD and CDRs... i used Tmpgenc to convert an AVI file to MPG1 followed the guide on this site... burned the MPG file fine onto a SONY CDR... but once i pop into my player it wont play??any help would be greatly appreciated
  2. Member Treebeard's Avatar
    Aug 2002
    What burning software did you use?
    did you make sure you chose to create a vcd with that software?
    Sometimes dvd players dont like certain brands of cd-r discs.
  3. When i burnt an mpg file as a vcd( converted with tmpg then burned it with Nero), the same thing happened to me on my Toshiba Sd-2800 dvd player. Basically what i did was even though the cd was brand new by shirt and pressed against the back and front on my cd( sounds stupid I know). I put it back in and it worked
  4. Originally Posted by knowell
    did you burn the cd as a vcd or did you jsut burn the mpg file?
    Time's not wasted when you're wasted all the time.
