ok, i was needing to adjust my bitrate since a standard svcd wouldnt fit on 2 cd-rs. so i made an xsvcd, since this is the only way to mess with bitrate of an svcd. the output was a terribley small img file that wouldnt even play in vlc, it just had scrambled green shaded video. any idea what the hell is goin on? what did i do wrong? i didnt change any other settings besides the bitrate. if im correct, svcd always has a bitrate of 2500 and its unchangable, so i went to xsvcd so i could adjust it to 2070. it should produce a file probly around 650-700 MB or so but instead it makes a .img around 200 MB! anyone have any idea what to do? im so confused...
also, as a different note- my input .mov says it has a fps of 23.77 in QT, but ffmpegx doesnt seem to let me change the fps to sumthin other than a default without getting errors in terminal. should i just set it to NTSC FILM (23.976), will it affect it much? any ideas?
Welcome to Darwin!
[Robert-Tollefsons-Computer:~] robertto% pbpaste | sh
## Component Manager: attempting to find symbols in a component alias of type (imdc/MPG4/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP42/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP4S/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (sdec/MS42/FhG )
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP43/MSFT)
INFO: [mpeg2enc] Selecting SVCD output profile
INFO: [mpeg2enc] Assuming norm NTSC
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/robertto/Desktop/vanwilder-svcd-1.m2v
INFO: [mpeg2enc] Horizontal size: 480 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 2069 KBit/s
INFO: [mpeg2enc] Quality factor: 2 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 800 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 230 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
*** malloc[435]: Deallocation of a pointer not malloced: 0x27ea8b; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
*** malloc[435]: Deallocation of a pointer not malloced: 0x27bf9b; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
*** malloc[435]: Deallocation of a pointer not malloced: 0x16862cb; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
INFO: [mpeg2enc] GOP LENGTH = 15
INFO: [mpeg2enc] Frame start 0 I 0 0
((-"encoding info, encoding info, blah blah blah...."-))
there u go major, hopes this helps u offer any suggestions...
thanks!
Muxing problems with ffmpegx
By Themroc in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 20:49 -
ffmpegx problems with RM to AVI
By mgarman14 in forum ffmpegX general discussionReplies: 13Last Post: 2nd Sep 2008, 13:45 -
ffmpegX Installation problems....
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 02:32 -
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 21:46 -
ffmpegx Problems! Help!
By The Sumerian in forum ffmpegX general discussionReplies: 4Last Post: 10th May 2007, 01:36
