Whilst doing my first capture tonight I ran into the "maximum file" etc message on Premier 6.01 Reading the posts I realise that my problem may be solved by converting my FAT32 drive to an NTFS one. Before I do that though I want to make sure I'm not going to lose anything because...
I have a Fat32 40gig HDD that is on a Dual boot (98 & XP). The 98 drive I use mostly for burning as XP didn't want to play ball. I also have a separate Fat32 120gig HDD which I was using for video. Now, can I convert just the 120gig HDD to NTFS (and would that solve my problem)? or do I have to convert both drives (and would that affect the dual boot)?
thanks in advance
as long as you dont use the 120 gig drive in win98 you can convert just that drive to ntfs.
IF you need to have access to the 120 gig drive from 98 you can get ntfs drivers for 98 ... i dont recomend that though ...
use default ntfs sector size or defrag will not work .. (the built in one) -- seems a bug in win nt os's .. -
Thanks for the info. Just to clarify...
So, if I convert the 120gig HDD to NTFS and put all of my video software programs over onto XP (most are on the 98 partition) I should be OK?
Many thanks
there are also programs that will allow windows98 to read NTFS. I can't say if it will be fast enough to capture, but will give you access to the drives.
http://www.winternals.com/products/fct/ntfswin98.asp
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 02:06 -
Converting External HD's from NTFS to Fat32
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 30th Oct 2010, 14:04 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 17:09 -
For backup, NTFS or FAT32?
By coody in forum DVD RippingReplies: 16Last Post: 1st Oct 2007, 10:30 -
HDD problem NTFS vs FAT32
By edsmith77 in forum ComputerReplies: 4Last Post: 21st May 2007, 12:17
