I have downloaded some divx/avi files but when i load blade2 for instance into v-dub to save out the audio to wav in full processing mode it gives me an error "audio compression not compatible with imput format" I have saved it out in direct stream but when i play it back it gives error "unsupported audio format" I have noticed in the file info tab it says unknown compression for audio.I think there must be a new audio compression codec out there as its only affecting some of the very latest divx films.Can anyone help?? Spaceman
try saving the audio to an uncompressed wav file and then re-compressing the audio
Big_Jit -
Have just tried that but when i try to compress the audio i get the same error as before"audio compression not compatible" Spaceman
Have just tried that but when i try to save out with compression i get the same audio compression not compatible error..Spaceman
Unlikely. Have you tried *Direct stream copy* and treating it as AC3? The only audio compression formats around are ogm, mp3 and AC3.I think there must be a new audio compression codec out there as its only affecting some of the very latest divx films.
There are others, but you are very unlikely to come across them.
How do i go about treating it as ac3 ?? Its wierd how the divx file plays back fine in wmp and realplayer but the direct stream audio just dont want to know, have come across 3 films in the last few days Blade2,JohnQ and Harts War all with this problem. At the moment i'm having to just use tmpenc which works ok but i like to run the wave thru besweet and change from 23.97fps to 25fps
If it is AC3, extract as a "wav" using Direct stream copy, and change the extension to .AC3. If it is, it will load into HeadAC3che and you can convert it to to wav.
Get HeadAC3he at http://www.doom9.org/Soft21/Audio/headac3he-0.23a.rar
Occasionally I come across DivX which have mp3 audio which will not extract in the usual way in Virtualdub. In these cases, extract the "wav" using Direct stream copy as before, and change the extension to .mp3. Use any prog you like to change the mp3 to wav.
I would bet that your audio is one or the other. 8) -
Thanks for the help banjazzer i have downloaded headac3he and will try it on my next job.Ii have also found another solution which was save out the audio in tmpgenc and convert the (in my case) 23.97fps mp2 to a 25fps wave using besweet then load the wave and divx in v-dub and save out at 25fps,which has just done the trick for blade2....Spaceman
M4V to AVI in VD, when compressed with Xvid, saves with audio out of sync
By kiki hayes in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2011, 10:45 -
VirtualDub won't open divx movie
By shmish in forum Video ConversionReplies: 9Last Post: 15th Mar 2010, 08:54 -
VirtualDub Won't read FLV Files
By Markgc in forum EditingReplies: 24Last Post: 20th Nov 2009, 20:25 -
virtualdub won't encode anything
By johnr283 in forum EditingReplies: 5Last Post: 17th Sep 2009, 21:33 -
VirtualDub Won't Let Monitor Power Off - Any Solution?
By Chakra in forum Newbie / General discussionsReplies: 9Last Post: 12th Oct 2008, 20:06
