Quick question. I've got a DVD9 I want to put on a DVD-R and so I recoded the video to a smaller .m2v but the audio is a 1.6gb PCM 2channel wave file... I notice in TMPGENC it mentions you can store a longer movie if you use mp2 audio.. How can I get my wav to an mp2 audio file? Do I just need to convert it from .wav to .mp2? I'm only familiar with mp3 not mp2. Will maestro load in the .mp2 file? I'd like to use the mp2 audio file to save some more space as the audio file is really large at 1.6gb as it's uncompressed..
Please let me know if you guys have any ideas on this...
Spudz2
convert your wav to .mp2 using TMPGEnc
1.)Open TMPGEnc
2.)Click Browse next to Audio input
3.)search for your audio file and click open
4.)click on Settings
use Stereo for 192kbps and higher - joint stereo for lower than 192kbps
since the source is DVD use 48000hz
I click add error protection but it's up to you...
click ok
click StartBig_Jit -
If you use smartripper to demux it to an .AC3 file it will be a fraction of the size, probably about 300mb.
then you can load it into an authoring program like spruce-up along with the mpeg and re-author, at least this way you keep the original sound quality -
Big_Jit: Thanks for that info.. I had no idea you could use TMPGENC for that.. I'll give it a shot and report back..
spookie: I don't think that this applies to my situation because what I'm ripping doesn't have AC3 audio it has PCM 2CH audio.. It's a music video mix DVD so not AC3. So I don't believe your suggestion would help me in anyway.. but thanks for the suggestion anyway...
Spudz2
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
MP2 audio with LAME?
By RogerTango in forum AudioReplies: 7Last Post: 3rd Nov 2009, 22:28 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 14:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10
