Hi there I've been following the guide to copy dvd to vcd and svcd using Smartripper/DVD2AVI/TMPGenc/Nero. Vcd's play fine, Svcd's wont play at all. I have a Sony s505d player (HK version of s715).
Is it a limitation of the player?
Would appreciate any help.
http://www.vcdhelp.com/dvdplayers.php
CHECK HERE TO SEE IF YOU PLAYER IS COMPATIBLE FOR SVCD'S -
if its not listed, replace your player to one which IS LISTED.
pure and simple. -
Try playing the SVCD on someone else's player. That way you will know for certain whether it is the disc or the player. 8)
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
