The only authorware I've used is MyDVD because it came with my DVD burner. It only suppots PCM audio which uses 40% of the file for audio. Reduces by about 25% the video you can store! Which authorware supports AC3 audio ??
Spruceup , Spruce DVD Maestro, SONIC Scenarist , SONIC SOLUTIONS DVDIT! PROFESSIONAL EDITION , Spruce DVDVIRTUOSO , Pinnacle Impression DVD-Pro
DVD Workshop. (You have to multiplex video and AC3 streams before importing to the program - use TMPGenc utility to do this). DVDWS will author without reecoding if your file is compliant.
Originally Posted by ahfairley
Originally Posted by wulf109
http://www.vcdhelp.com/forum/viewtopic.php?t=113470&highlight=
see the links here i sent you .. its free to encode 2ch to 5:1 ac3 ... -
just a question - does tmpgenc multiplex correctly for dvd ? (i.e. correct audio pregap and pack rate?) because i thought its only multiplexer was for vcd and svcd headers w/ vbr ...
i didnt know it could even multiplex ac3 -- learned something ... not that i need to multiplex it as the authoring program does it .. -
I've multiplexed 2/0, 3/0 & 3/2 AC3 with it and the burned DVDs play just fine. I don't know whether DVD WS is doing something extra to the file after its imported (it definitely doesn't reencode the video)
DVD Authoring for MKV files and dts, ac3 support
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2011, 16:32 -
Amateur Question: My DVD9 doesn't support AC3 Audio
By Keziapurrs in forum AudioReplies: 15Last Post: 10th Jul 2011, 19:03 -
Recommended DVD authoring programs...
By mjl1297 in forum Newbie / General discussionsReplies: 23Last Post: 18th Feb 2010, 21:14 -
Converting AAC to AC3 (for DVD authoring), losing audio
By senorroboto2k5 in forum AudioReplies: 3Last Post: 16th Feb 2010, 18:03 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 11:25
