  1. I am able to import a ripped m2v file into TMPGEnc but it shows up as being 0 in size. What is the problem?
    Apr 2002
    Oskeeweewee Ontario
    Ummmmm, just out of curiosity, when you see that 0KB filesize, is it a newly created file? You probably already know, but just in case you don't, go to the top of you Explorer, and click view>refresh. Or F5.
  3. The m2v file shows up in explorer as 4.2gigs and it will play in WinDVD. It's just when I import it into TMPGEnc that it shows up as 0. I use the wizard and when I get to the page where the bitrate is set it shows 0 in the content bar. I am able to open the file in Spruceup and burn a viable DVD. What is odd is that I can record the DVD to a DVD-RW and rip that to the hard drive and that m2v file shows up fine in TMPGEnc.
