Grrr! Another issue!
I cant get ac3 to import into DVDmaestro, yet the same streams work fine in Ulead DVDworkshop.
The AC3 streams were exported from AVI's with VirtualDubAC3, and play fine in wmp.
The actual error is:
Unsupported Media: Invalid Wave Format (only WAVE_FORMAT_PCM format is supported) (0xc10b0008)
I've tried renaming the ac3 to mpa - no joy.
Dammit Dammit Dammit! One problem after another, so far got around each one so far.
Now this.
Any ideas?
That is a problem with the high quality programs - they seem to be overly concerned about a properly encoded file that meets the DVD standard. The "junk" programs, like all of Ulead's stuff, don't seem to know what is required for the standard, so will let anything through.
My suggestion to you, is to get your .AC3 file with the correct header / correct encoding. -
Hi,
Had that problem myself, Try using a program called AC3fix
to sort out any bad frames in the .ac3 file.
first rename the extracted file as an .ac3 and run that little prog.
i've had this problem when i've extracted .ac3 files using virtualdub,
normal it seems to be when the original .ac3 file has been split into
2 halves.
anaboland, where can we find this ac3fix? I didn't find it in the tools section here.
TIA
::Edit::
Nevermind. Finally found a working link for a site in Taiwan (sp?)
::Edit::
Can't Import Video File with AC3 Audio into Vegas 9 Platinum
By Charlie_L in forum Newbie / General discussionsReplies: 11Last Post: 2nd Sep 2011, 07:44 -
AutoGK hangs during AC3 import process...
By takearushfan in forum Video ConversionReplies: 8Last Post: 11th May 2011, 05:31 -
SOLVED: Can't Import AC3 audio in Virtual Dub 1.9 Stable
By mlong30 in forum EditingReplies: 2Last Post: 15th Jan 2011, 02:12 -
DVDMAESTRO sx32w2.dll
By twinegar in forum Authoring (DVD)Replies: 1Last Post: 16th Mar 2010, 12:04 -
Can't import AC3 to DVD Architect?
By zovx in forum Authoring (DVD)Replies: 9Last Post: 11th Feb 2010, 18:53
