DVD-R/RW Computer Drives and DVD Recorders Require Firmware Update for New High Speed Discs
LONG BEACH - As the DVD Forum releases the specifications for new high-speed discs for DVD recording, Pioneer Electronics (USA) Inc. announces that many of its DVD-R/RW computer drives and DVD recorders will require a firmware update in order to avoid potential damage to the units and discs.
The update process is free and relatively simple, and it is extremely important for owners of these products to make sure it is completed prior to using any new high-speed discs for recording. The DVD Forum has established new standards for high-speed recordable discs (4X for DVD-R and 2X for DVD-RW). Various media manufacturers have begun production of these discs that will soon be available in the marketplace.
The source of the problem is a firmware bug; in certain Pioneer DVD-R/RW recorders and drives, and not with the high-speed media itself. As a result, use of the new high-speed discs for recording on these particular Pioneer products may cause damage to both the loaded disc and to the drive/recorder. The following drives and recorders may be affected:
Pioneer DVR-7000 DVD recorder
Pioneer PRV-9000 Professional DVD recorder
Pioneer DVR-A03 computer drive
Pioneer DVR-103 computer drive
Pioneer DVR-A04 computer drive
Pioneer DVR-104 computer drive
In addition to the above models, certain OEM computer systems containing Pioneer-manufactured DVD-R/RW drives are affected. Anyone who owns or uses any of the above-listed products should conduct the free firmware update immediately, prior to using the new high-speed media. Go to http://www.pioneerelectronics.com/hs/pioneer.html to download the new firmware.
Gary
Videoguys.com
How to replace new DVD burner and HDD for pioneer DVR-550H?
By voa in forum DVD & Blu-ray RecordersReplies: 5Last Post: 20th Mar 2012, 09:35 -
Fixing/Replacing DVD-burner (Pioneer 630-H) -how?
By tigrr in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Feb 2011, 17:20 -
Pioneer DVD-RW X162 External Burner ???
By blinky88 in forum DVD & Blu-ray WritersReplies: 4Last Post: 9th Aug 2009, 06:03 -
Pioneer DVR-543HS , is my DVD burner toast?
By stew182 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Sep 2008, 13:57 -
Trouble burning DVD+R DL with Pioneer burner
By RoyGBiv-inRI in forum DVD RippingReplies: 11Last Post: 17th Oct 2007, 11:43
