Ok, dramatic subject... not as exciting problem
I'm converting a DivX that's in 23.97 FPS...
The problem is that I want the XVCD to be in PAL format...
But I get about 1 FPS that's "corrupted"... It frezzes for a little while before continuing to play...
It does this all the time! I've tried most thing you could think about!!!
Magnus Jensen
A.K.A Geezus -
if by PAL format, you mean a 25fps framerate XVCD, then what you are probably seeing is not a corrupted frame, but the effect of having added a frame to get from 23.97fps to 25fps, which is probably very annoying visually.
just wondering if you could get away with a non-compliant 24fps "PAL" XVCD...
I managed to get this working without any jerking...
The trick was to use a... digital audio editing program... (Soundforge 4.5)
This program is lovely! Not only did I get the 25 FPS i wanted, it was chopping free AND the audio was in Perfect sync!!!
This is a tip I think that most people will enjoy
Kinda fun that a audio program did the trick!
I had to reencode the whole thing though...
Magnus Jensen
A.K.A Geezus
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 11:07 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 20:45
