So... am using Adobe Premiere 6 with a DV500plus. Now at the stage where I want to burn to DVD. Tried a test with a DVD writer but the quality burnt to the disc was sub standard.
Can you help...
Best DVD writer to buy? theres a lot of talk about pioneer 104
Best DVD Authoring/Burning software? (Ulead Workshop???)
All I want to do is retain the picture quality and create chapters.
Can you help? All suggestions welcome.
Cheers[/b]
newbie
For authoring/burning/chapters all You need is Ulead DVD MovieFactory $44.95. You can also capture and do simple edit. Quality is pretty good too, but be aware - every cut/merge means re-encoding. Download demo and check for Yourself, what it is capable of. IMHO Workshop is way overpriced for added functionality.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
