Hi,
I burned my VideoCD´s with Roxio´s own VCD Player, which is starting everytime a disc is inserted.
Now, I want to play back the VCDs with PowerDVD. Unfortunately, the Roxio Player is also starting. Can I deactivate it somehow?
what OS are you using? There may be a way do change this through OS options. Also, I haven't used Roxio's player in a while, but I believe there is an option in there somewhere that lets you choose whether or not you want the Roxio player to be the default player for VCDs.
Good luck,
Prospero -
That's weird, I can see this when I click on the thread, but the update doesn't show up on the counter in the forum. Oh, well, maybe this message will make it show up.
hit shift as you insert the disk. This turns of autorun/scanning for that insertion only.
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 17:30 -
Roxio ?
By reygato in forum EditingReplies: 3Last Post: 20th Apr 2010, 08:50 -
Deactivate video playback
By Gswiss in forum Software PlayingReplies: 5Last Post: 25th Oct 2008, 05:48 -
Roxio Popcorn 3 - HELP?
By jphuber1959 in forum MacReplies: 8Last Post: 2nd Dec 2007, 14:50 -
Roxio vs Nero
By gthorley in forum Authoring (DVD)Replies: 25Last Post: 23rd Aug 2007, 03:08
