Hi i just started creating SVCD's after sucessfully creating VCD's. I notice that the SVCD template in TMPGe has a default audio bitrate of 128bps, but on the VCD template it is set @ 224bps. (both @ 44100Hz)
Is there must difference? What audio bitrate should i use?
Any Advice greatly appreciated.
Great Web Site/Forum.
You can use any bitrate from 32Kb/sec up to 384Kb/sec and up to 2 audio tracks with SVCD. You will hear a difference in quality between 128 and 224. I personally don't go below 192 but it depends on what the audio is. With music I think you can get away with a lower bitrate, but basically the higher the bitrate, the better the quality. You'll just have to experiment a bit. Try encoding 1 min clips of say music, talking, and loud action scenes. try them all at 128 and 224. If your happy with the quality then go for it. Quality is an extremely subjective thing and many people will give you many answers!
Good luck!Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour') -
VCD standart sets audio bitrate to 224 kbs. Point.
SVCD gives You more freedom (96~384) . What I would say, eperiment! It depends, what You record and from quality of encoder and also from playback equipment. Everything as with MP3. But unlike with DVD (bitrate-wise), the more You use for audio, the less will be left for video and these last tens of kbps-s may sometimes have decisive influence for picture quality.
I have used only 224 kbps, as my PVR-250 records at that and I don't want to re-encode, but I don't think, this is universal truth. -
Thanks for the advice, I will experiment with 192 & 224 bitrate levels.
Thanks again.
multiAVCHD audio bitrate?
By morghe-sokhari in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2012, 10:11 -
Difference in Audio Bitrate
By skorpinok in forum AudioReplies: 2Last Post: 29th Aug 2010, 13:47 -
mencoder AVI: invalid audio stream ID: 128 - ignoring (nosound)
By dialallama in forum Video ConversionReplies: 3Last Post: 4th Mar 2009, 09:17 -
Audio bitrate info
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2009, 16:50 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 23:40
