Tried a search, so sorry if this is in the knowledge base. Trying to back up Godfather 2, a 2 disc set. I ripped each disc to a separate folder. Then I noticed I was able to add the second discs' ifo and vob files to the list in DVD2SVCD by clicking on the little dots after the first IFO was loaded ; BUT, the play time did not add the 2nd discs time. Therefore, even if it processed OK, wouldn't my bitrate be wrong and leave me manual cutting and multiplexing? I have since planned to sqeeze disc 1 onto 2 CDR and do disc 2 onto 1 as a separate conversion, but would be nice to know how best to handle this kind of oddball case.
If you rip each disk to one large VOB (streaming mode) each and delete all other files DVD2SVCD will ask you to click on and add any additional vob's to encode both as one as it were - and the playing time will be correct. Is this what you were after??
sorry, u r correct. I forgot to check your computer details.
Ok, you should be able to split the vob's (under 4gig each) , delete the ifo files etc.
and it should still work. Other than that all I can suggest then is to repost your Q in the DVD2SVCD
forum at doom9.org - you will have to wait 5 days to post after
registering though.
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 16th Feb 2012, 23:54 -
entire disc rip Drilbit Taylor Region1
By greenapple in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 03:09 -
Can not rip DVD-R disc (not retail)
By NotSoEasy in forum DVD RippingReplies: 47Last Post: 14th Jan 2008, 01:25 -
2 disc movie to RIP and Burn
By naftalim in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2007, 12:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 12:50
