Hi all,
I've problem with signpost files - response is very slow. Opening anything in tmpgenc takes 3-5 minutes, but when I run conversion it looks like frameserving is working correctly - 2,5 - 3 hours and output is OK. I'm using VidrtualDub 1.4.9 with tmpgenc 2.58 running on Windows XP. Changing tmpgenc options does not change anything. Anyone knows what is going on?
Thanks,
Krzyhoo
You might need to set the DirectShow Multimedia file reader to a higher priority under the environmental settings vf-api tab.
Big_Jit
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
VirtualDub problem: it's slow with karaoke encoding... Why?!
By matsujunna in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2011, 01:34 -
Virtualdub-like slow motion for x264 clips?
By spinmonk in forum EditingReplies: 15Last Post: 19th Sep 2009, 13:33 -
Encoding with VirtualDub the second time around is very slow
By Megahurts in forum EditingReplies: 9Last Post: 7th Mar 2008, 00:02 -
Slow skipping response on MPEG1 2-pass VBR
By sparkomega in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2007, 00:19
