I've captured old videotapes as AVI, converted them to VBR MPEG1 with TMPGEnc, and burned them to CD-RW using VCDImager. The MPEG files are perfectly in sync when I play them back on my computer, but there is a slight audio lag when played in my DVD player. Does this mean I probably need to lower the bitrate a little, or is there some other possible cause?
Unfortunately you didn't say at which VBR in mpeg1 you are using. But it most certainly sounds like your DVD player can't encode that fast. Better to lower the bitrate somewhat. There have been postings that certain media (CD-RW) can cause this effect as well. If it's a rumour or not I cannot say, as I have never had these problems.
It's TMPGEnc CQ (Constant Quality) 50 encoding, at 2500 Kbps. It's an inconsistent problem, as many tracks seem to play just fine, but nonetheless, I'll try easing up on the bitrate a little. Could using the fast-forward seek function on my DVD player also have some impact?
Yes the FF/FREW, pause etc. basically anything that interrupts the normal "flow" has an impact.
2.500kb/s is a rather high bitrate for mpeg1.
tsMuxeR and Audio Lag
By imrealdumb in forum Video ConversionReplies: 3Last Post: 14th Jun 2011, 18:28 -
Audio lag after conversion to DVDmpeg2enc
By macgurl in forum ffmpegX general discussionReplies: 5Last Post: 8th Aug 2010, 02:42 -
DVD RIP, Audio and Video Skip/Lag
By Blue_3 in forum DVD RippingReplies: 4Last Post: 8th Apr 2008, 07:34 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 08:03 -
After using ConvertX, major audio lag
By bear2616 in forum AudioReplies: 4Last Post: 17th Oct 2007, 13:42
