  1. I completed a video cd with MPEG 1 - and now i read that i can improve on the quality by using MPEG 2 instead. Is this true?
    Using the same mpeg 1 video, can i convert it to mpeg 2 and then burn it on a vcd?
    Do i use TMPGEnc for this?
  2. Guest
    Just reencoding the mpeg1 to mpeg2 does not improve the quality it will instead decrease the quality a bit. And VCD is MPEG1 only. But if you have a good video source like dvd, very good high resolution divx, dv or some captured high res avi you can try SVCD.
  3. Every time you re-encode something your going to lose quality. It's like taping a video over and over. You lose something each time you try to compress the file. You do get better quality with SVCD but you have to use a higher bitrate because the resolution is much bigger than VCD.
    SVCD = 480 x 480/576 (NTSC/PAL)
    VCD = 352 x 240/288 (NTSC/PAL)
    For example a pal VCD has 352x288=101376 pixels per frame, whereas a SVCD has 480x576=276480 pixels per frame. As you can see there is a ratio of 2.72 to 1 so technically you need 2.72 x the VCD bitrate to achieve the same quality. Of course when using SVCD we use 2 pass VBR which gives better quality at lower bitrates. There are plenty of guides on this site to explain how to make a SVCD. I personally agree with test and would only use SVCD from a high quality source like a DVD rip or similar.
    Have you tried XVCD's (if your DVD player supports them)? You can increase the quality of your VCD's using higher bitrates and 2 pass VBR. Of course this means splitting the movie over 2 or 3 CD's but you can put 1 hour of video encoded at 1581Kb/sec using 2 pass VBR onto 1 80min CD. The quality is excellent (in my opinion) and most movies are under 2 hours so the bitrate can increase if the movie is shorter. I recently ripped Shallow Hal onto 2 CD's at a bitrate of 1710Kb/sec using 2 pass VBR. On my 25" Sony TV it looks just about as good as the DVD. If you didn't know any better you would be fooled when watching it.
    Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour')
