What is the best burning program. I currently use vcdeasy.
If you are authoring/burning S/VCD, you can't get any better than VCDEasy. For anything else, Nero is the King, (or an Emperor?
What i do i just encode the .ifo file to mpeg2 in dvdx v 2.0 and then burn the mpeg2 file with vcdeasy. Is that the best way?
nero is really good, but I usually use roxio easy video creator because its really easy to use.
Burning Data Program on DL discs?
By PowerFalcon in forum MediaReplies: 2Last Post: 27th Jul 2011, 07:58 -
Program for simple editing and burning
By hodocka in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2011, 22:16 -
VIDEO TS Burning Program
By videocheez in forum Authoring (DVD)Replies: 2Last Post: 30th Jun 2009, 05:55 -
Burning program options
By efiste2 in forum DVD RippingReplies: 4Last Post: 14th Jul 2008, 18:44 -
Whats the best DVD burning program out there?
By Tielurr in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 18:21
