I've got a subtitles file, which is about 1 minute late.
Is there a way to sync the subtitle, and which prog?
TIA![]()
Yes, there is a way to sync your subfiles. Here are my 2 favorite progs to do it:
1. Sub Station Alpha. Determine in your movie as good as possible where the first word is spoken.
- Open Sub Station Alpha(SSA)
- File
- Insert Script(select your file which must be in SSA format)
- Adjust timings and enter the timing you found before
- Save this file and give it another name so you know which one it is
- Test your new subfile.
2. Subsync. This is a good prog to determine the first spoken word. Open the prog, push the select button on the media line and open your movie.
You can also adjust the timings of your subfile with this prog, but since this a long explanation and I'm lazy
, first try it with SSA. If that doesnt work, just ask me how to do it with Subsync
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
How to sync subtitle to another subtitle?
By mriddler in forum SubtitleReplies: 6Last Post: 1st Apr 2010, 04:07 -
How do they sync the subtitle in the first place?
By mohalfares in forum SubtitleReplies: 2Last Post: 24th Oct 2008, 10:33 -
Subtitle always out of sync
By nonkeljef in forum SubtitleReplies: 3Last Post: 1st Aug 2007, 14:37 -
Subtitle formats and sync
By Raztax in forum SubtitleReplies: 4Last Post: 13th May 2007, 13:49
