I can't get any of the VCDs I burn 2 play I have a sony DVD player and I'm using Imation CD-R media, my DVD player just says " NO DISK " I've tried burning w/ Nero, EZ CD 5, VCDimgagerGUI, File burner and nothing seems 2 work, Could it be a problem w/ the media I'm using cause my DVD player supports Video CDS.....Any help would be much appreciated
What program did you use to convert to MPEG-1?? I reccomend using Tmpgenc ... also your DVD player MAY support VideoCDs but some Sony players cant read CD-Rs or CD-RW.
Hi,
Try with APEX AD-660. It takes any video cd whether it is PAL or NTSC. It will also take any video cd you burn. I had a hard time, playing myvideo cds but this player solved all my problems.
Peter Kennedy -
I'm using VCDImager GUI to convert to MPEG1 I've accually have gotten one of my movies 2 play on my DVD player But I've downloaded as a bin file I've compared it to the other VCDs I've burned and they seem 2 be the same but the only difference is that the bottom of the CDR media looks dark green and the ones i'm using now are light green??Not sure if that will make a difference but??
---What is APEX AD-660 I assume its hardware were can I get one....Thanks----6sic6-----
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 20:28 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
