Is there a way i can mae a smaller mpg? I was adding movie clips together and i end up with a file that was 2.2gigs. I dont think thats how big the clips were combined.
Is there any way i can make the mpg smaller i am mainly using adobe preimere 6.0.
You can either split it (TMPGenc | MPEG Tools), or re-encode it to a lower resolution/bitrate (ReMPeg). You should be able to find them either here, or at the Doom site ( www.doom9.org )
is there any way to make the mpgs smaller in adobe? or tmpeg? I cant seem to get rempeg to work right.
making mkv smaller
By jetli68 in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Sep 2011, 11:31 -
How is a Smaller File a Better One?
By happydog500 in forum Capturing and VCRReplies: 4Last Post: 23rd May 2011, 20:50 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
plan for converting SageTV mpg's to smaller files.
By Verlager in forum LinuxReplies: 7Last Post: 6th Feb 2008, 22:56
