  1. when i open up DVD2SVCD, and try to select my .ifo file, but i get a message that goes like this: The AVisynth BMP loader dll file does not exist! C:\Program Files\DVD2SVCD\Avisynth BMP loader.dll
    what should i do?
    thanx
    Jul 2002
    St. Louis, MO USA
    DVD2SVCD needs to know where all of the applications and .dll files it needs reside. I am at work and doing this from memory but I think there are little "file open" icons, about a dozen of these throughout, some on just about every tab. Click "open" and it tells you what file it's looking for. Simply find the one it's looking for and "select". Is this the first time you've tried DVD2SVCD? If not, and you've done all these selections before, then maybe the file it's looking for was accidentally deleted. Check in the zip file you downloaded for Avisynth BMP loader.dll, or else download again.
    Feb 2001
    Berlin, Germany
    I thought Avisynth BMP loader.dll is part of the dvd2svcd bundle. Try to reinstall dvd2svcd or download the plugin here.
    The plugin is used to convert a still image to a short video clip.
