Ok, when i burn a vcd and play it in my dvd player, the sound skips and is all messed up. I want to know if i burned everything ok. Also, the movie plays fine on my computer (perfect sound and picture). Am I burning it wrong? BTW, i use CDRWIN, burned at 4x speed and as a cue and a mpg. My dvd player plays other VCDs, just certain ones the sound skips.
3 things:Originally Posted by New2TheGame
1--download a sample VCD from here, and try burning and playing that.
if that works, then you know the problem was with the VCD you made
2--did you change the audio to 44.1 khz?
3--is it maybe a PAL VCD playing on NTSC system?what are you askin' me for...
I'm an idiot!
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
