    May 2002
    Arizona
    I'm running Win 2K with dual 1900+ Ath. I capture and export using firewire only. I don't have a "capture card" yet.
    Everything was fine . No limit on the amount of video capture.
    Untill.....
    Just for s..t's and giggles I load in Ulead 6.5
    Now when I go to capture in premiere the system locks up after about a minute of capturing. I now have to reboot.
    So I remove Ulead but premiere still freezes the computer during capture.
    What the hell did I do??? More importantly - how do I fix it?
    Mike
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    sounds like ulead installed its own codec (or changed a reg info) .. you might try to remove it or any other ulead drivers in system32 folder or drivers folders ..
    then perhaps re-install adobe ...
    del all ref to ulead in registry ...
    one or more of the above may help ...
    May 2002
    Arizona
    I'll try it tonight and let you know!
    Thanks!
