I'm converting 3 seperate 45min(aprox) .vob's from a mountian bike dvd. Wondering if i should go vcd or divx. would like some opinions on what programs to use and setting to run it at. the vob is 720x480 NTSC 29.97fps
Thanx for any help
<font size=-1>[ This Message was edited by: BiteMe on 2001-08-15 14:48:41 ]</font>
The question one has to ask is what you intend to do with the finished results. No DVD Player can play DivX files yet and if you distrubute a disc containing this file (for others to play on their pc) you would have to make sure that every one has the same codec. If you choose VCD (mpeg1) its more likely that a standalone DVD player could play it, but most certain that a pc would be able to.
As for sharpness and high motion scenes it all depends which codec you use in DivX or which bitrates you would use in mpeg1.
May be End Action Question
By philwright11 in forum Authoring (DVD)Replies: 11Last Post: 29th May 2011, 14:32 -
Action style HD camcorder
By SlyTX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 19th Nov 2009, 17:39 -
fast action blurs
By johnsees in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2008, 00:23 -
Help with sports action shooting
By cobra jet in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2008, 15:52 -
Custom DVD Action
By marioval in forum Authoring (DVD)Replies: 7Last Post: 11th Jan 2008, 09:05
