  1. i have a .bin file of a vcd.. i can use win iso and extract the AVSEQ01.DAT but how do i convert the dat to mpg?? renameing wont work because xp wont let me change the file extention.. HELP!
  2. Banned
    Jun 2001
    UK
    You don't need to convert it to anything, all VCD authoring programs will let you load the .dat file in.
    You can also load the .dat file into TMPGEnc if you need to, and Vdub (Mpeg 1) the .dat files is already a mpeg 1 if its from a VCD
  3. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    IsoBuster, CDMage....
    You can't fool me, I'm a moron!
