Hi
I have a ATI TV Wonder (TV Card). I am basically wondering if there is a way to capture at DVD res either 720 x 576 or 720 x 480.
I understand that there maybe a way to capture @ DVD Res in Virtualdub.
I would like to know if i can capture @ DVD Res using my normal ATI TV Card program.
The highest Resolutions i get at the moment are:
NTSC : 620 x 288 (I think)
If there are any methods to capture at DVD Res using both Virtualdub and my standard ATV TV Program..please reply
thank you
Results 1 to 15 of 15
ATI TV Wonder does not use the standard BT8x8 chip, so you cannot use the generic BT VFW and WDM drivers for this card. ATI limits their drivers to x240 for this card. You might be able to mix and match some wrappers and other drivers and stuff and perhaps get 720x480, but I would not hold my breath. This is why I always suggest people get the Hauppauge TV tuner card instead of the ATI TV Wonder card. The Hauppauge card can do 720x480 with both generic and original drivers, and both VFW and WDM drivers are available.
720*480(576) with a TV wonder PCI is no problem and it does use the booktree 8x8 and video for windows is no problem - wdm though is a pain in the rump.
get iuvcr which uses it's own directshow drivers or download the 3rd party bt8x8 VFW drivers and use them with virtualdub.
i know, i own one. -
AnonymousGuest
It seems that the only legal way to get ATI TV V 6.3 is to purchase a card and the CD that came with it on e-bay?
Check this ATI site for the latest drivers. The new drivers may work for you. http://mirror.ati.com/support/driver.html
nah, a google search should find you MMC 6.3 - I didn't have any problem finding it when I went looking.
filename was ati-mmc63cz.zip -
Hey FiEND,
I tried lookin for the 3rd party bt8x8 VFW drivers but I cudnt find them
cud u please send them to me? Upload to somewhere and provide a link?
Or just holla at me on:
MSN : Imyashy@hotmail.com
AIM : Imy7584
Thanks in a advance
7th thread from the bottom here
http://www.vcdhelp.com/forum/viewtopic.php?t=112597 -
there is no link in the 7th from bottom reply
can u just post the link here pls? -
thanks everyone for ur help
I wil try out these methods and see if they work
okay...I used iuVCR and I can now capture in DVD RES
thanks ppl...btw, the bitch thing is, I CANT CAPTURE AUDIO
see my post about problems with audio capture.
Okay with the iuVCR software, i can capture @ DVD Res Into AVI format. Is there any way out there where i can capture at DVD Res by Using realtime MPEG-2 Capture?
Holla...!
Imy -
AnonymousGuest
Hi,
Turn on your vcr first. Go to Source, choose cable and channel 4, then put it back to channel 3 and select SVCD. The sound will come through then.
That had me messed up for a while, too.
Later.
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
I can't get my ATI tv wonder PCI 650 to capture
By Onceler2 in forum Capturing and VCRReplies: 5Last Post: 28th Nov 2009, 10:47 -
320x240 res video onto dvd
By scarypoultry in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 17:30 -
Advice on High Res Video Capture Hardware
By Gregus in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 15:54
