I got some Music Videos on VCD disks. I want to extract the videos off those cds and put them on DVD. anyone know how?
Results 1 to 10 of 10
Is there one large .dat file on the disk ? if so all you need do is copy the .dat file onto your hard drive Then you can use TMPGEnc to convert it for DVD (Load a DVD template)
If there are several .dat files you need to work with one at a time. -
KingJohn said:
why bother, they are already DVD compliant (assuming they are fully VCD compliant!) except the audio needs to be at 48Khz. Many DVD authoring proggys will do this conversion for you - no need to re-encodeuse TMPGEnc to convert it for DVD (Load a DVD template) -
DVD PAL (MPEG-2 720x576 25fps CQ 65, Layer-2 48000Hz 384kbps)Originally Posted by bugster
DVD NTSC (MPEG-2 720x480 29.97fps CQ 65, Layer-2 48000Hz 384kbps)
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Some people prefer to do it correctly -
What bugster stated is absolutely correct.
There is no need to re-encode the video component at all, just the audio (after resampling to 48 kHz).
MPEG-1 352x240/288 at VCD bitrates is perfectly compliant within DVD specs:
http://www.vcdhelp.com/dvd.htm
The DVD FAQ provides more details.
Re-encoding the video will only lead to a further generational loss of quality.
Regards.Michael Tam
w: Morsels of Evidence -
KingJohn, I think you need to take a look at this:
Scroll down to the section marked technical info and I think you will find I am correct. -
Nobody is saying a mpeg 1 wont go on a DVD, but why tell people to do this, when files made for DVD are Mpeg 2 with AC3 which is a lot higher quality.
You will tell every one to transfer mpeg 1's onto DVD. Reading this post many will think to rip to VCD and place them on a DVD.
If vitualis says its correct then its definitely NOT -
Very petty KingJohn.
Read the original question. The person has VCDs and wants to transfer the video onto a DVD. You suggesting that they encode to MPEG-2 first is obviously not the best option.
Regards.Michael Tam
extracting hardsub
By Benjy in forum SubtitleReplies: 0Last Post: 17th Jan 2011, 10:40 -
Extracting frames
By tomblyn in forum Video ConversionReplies: 5Last Post: 28th Jan 2010, 08:01 -
extracting clips
By turdburglar in forum MacReplies: 1Last Post: 15th Sep 2008, 07:29 -
Extracting Subtitles
By Boiler98 in forum MacReplies: 5Last Post: 24th Jun 2008, 09:21 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 07:54
