I've tried to make my first X(VCD).. my standalone player could access the disc and display.. however, it displayed it at the very bottom right-hand corner. Why? In Tmpgenc I selected 2500 CBR, 720 x 480, full screen(keep aspect ratio 2), source was 1:1 VGA (Divx .avi). Anyone have this problem when trying to make a high res X(VCD)?? can I only use 352 x 240? and just up the CBR? Help much apreciated.. I've been making nothing but coasters the last few days.
Someone correct me if I'm wrong, but xVCD does not mean you can throw absolutely anything on a CD-R. You must follow some guidelines, the primary being resolution.
XVCD NTSC
Video:
any kbit/sec MPEG-1 both variable and constant bitrate
352 x 240 pixels
29,97 frames/second
(23,976 frames/second NTSC Film)
Audio:
32-384 kbit/sec MPEG-1 Layer2
Extra:
Menus and chapters
Still pictures in 704x480,352x240
Note that only STILL pictures can be 704x480. Your video is DVD standard. You cannot place video at that resolution on an xVCD and expect it to play.
You can place it on an xSVCD though. They support these resolutions:
352 x 240 pixels
352 x 480 pixels
720 x 480 pixels
Note, that these are all NTSC standard. You didn't specify.
Either reformat your MPEG to MPEG2, and make an xSVCD, or reduce the resolutino to 352x240. -
I had a video clip in a strange resolution and had similar problems in converting it to a VCD. I used center (custom size) option with TMPGEnc to solve it.
Take a look at Kwag's site, and see if you can find something which works for you. 8) http://www.kvcd.net/dvd-models.htmlcan I only use 352 x 240?
You can use 704x480 for mpeg1 i have used such before the link above at kwag has loads of decent templates inluding 704x480 for xvcd...Spacman
Thx for the replies,
I will try some of your guy's tips... and post what worked for me.
DVD resolution is 720 x 480 ??
By siratfus in forum Video ConversionReplies: 6Last Post: 3rd Mar 2013, 10:47 -
SD 720 x 480 - how do I upload to youtube so it fills the frame?
By Bansaw in forum Newbie / General discussionsReplies: 1Last Post: 25th Feb 2012, 02:50 -
Video Size 720 x 480 to 960 x 540?
By jiuvaro in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2010, 10:58 -
Newbie question about 720 x 480 dvd resolution
By siratfus in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2008, 18:30 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25
